DROUIN Supercharged Z1000A ..
post
Brill, this man is amazing at what he does and its not far from me too,Zed any chance I can pop and have a butchers in the flesh mate?
Ted
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
phil churchett
Re: post
If i make it to the yorks rally you can take a detour back to mine on the way home.ted1r wrote:Brill, this man is amazing at what he does and its not far from me too,Zed any chance I can pop and have a butchers in the flesh mate?
Ted
Its been a while since i've done anything worthy of note and there's a miriad of niggly bits you can't see that need sorting before its finally finished. However i have at last decided on a paint scheme and have been preparing the body work for the event. In the last posts i had modded the tank to take the race filler but wasn't happy where the hole intersected with one of the old spot welds towards the front of the tank which held the original cap mount. The metal in this area is also very thin due to corrosion and slightly distorted and although it does straighten out and seal when the cap is bolted on i have visions of the paint cracking so decided to create a solid flange that will take the cap and not flex when bolted up.
I machined up this 3mm steel ring
Which was then bolted flat to the tank
[b] Then pre heated the tank with an hot air stripper to reduce the heat differential and limit the risk of distortion when the ring was brazed in place
[b]And that i think is it for the bodywork , Just the addition of a breather and i'm ready for the paint which i hope to get away in the next week or two.
Another unplanned mod is to the kickstart which clobbered the toe peg of the brake lever. I had already made the footrest hinge up out of the way but obviously things never are that simple. I did toy with the idea of hinging the toe peg as well but decide that was a bit extreme and finally went for the easy option . I've had to heat the lever and bend it out near the pivot then bring the other end back up so it sits at 90deg to the frame as it should when swung out. This does bring the lever quite far out now so to combat any tendancy to twist or bend i've introduced a strengthening plate that as well as beefing up the shaft length ways is also positioned diagonally along the lever to resist twisting. Just got to get this powder coated and that's another item off the to do list.
It's not just the engineering skills that are highlighted during this project, it's the unique thought of overcoming every problem thrown at him
Amongst all the other work, the fuel tank filler is bloody excellent.
brian 450 wrote:Looking really nice mate. What colour is it going to be?
Pretty sure its gonna be classic zed green 'n' yellow now
Users browsing this forum: No registered users and 89 guests
