Lawson Jigsaw Project
- z1000puddin
Well then.
So, I proceeded to empty all the boxes & try to get some sort of order, to see just exactly what I have here...
The plan is to dry build it, then strip & send the various parts to paint , powder & polish.
I got to this stage today ....
What I do need to start with is...
* Clock assembly with a key
*Nose fairing & screen
* Starter motor
* a side stand bracket
I'm slowly getting through all the boxes & should have all emptied & on the shelf by tomorrow.
There seems to be lots of GPZ parts.
Also multiple brake discs, mostly all very good.
Multiple Clutches, Dyna S ignition plates, a scruffy kerker
A scruffy Harris, A pretty good V&H.
Some members have asked about parts, I will get back you guys via PM
* Starter motor
Zed til Dead
LeeJackson
Re: Lawson Jigsaw Project
That's a good stash of parts you have there Stuart, will be a fun project!! Looking forward to seeing it develop!
- z1000puddin
Thanks Lee,
If you are needing any parts, give me a shout, I'm still going thru
All the boxes, but there seems to be a lot of GPZ & J parts
Stu
Stu
Zed til Dead
looks like you've got quite an inventory of parts there.
im thinking of fitting a dyna2000 to mine. so if you have a j ignition case (the housing not the cover) i would be interested.
Your a Glutten for punishment...the garage looks as if I had never paid you a visit!!!
- z1000puddin
Gary
I know, I seem to have more parts now than I did before you cleaned me out.
How's my old zeds going ? Have ya got them MOTD yet ?
Zed til Dead
- z1000puddin
swampy wrote:im thinking of fitting a dyna2000 to mine. so if you have a j ignition case (the housing not the cover) i would be interested.
Swampy
There is a complete bottom end unitrack, but no ignition housing, sorry
Stu
Zed til Dead
ho hum
Julian_Boolean
I got my casing off eBay for £15, you can still buy them new for about 10 times what I paid.
- z1000puddin
Doing a bit more today.
Checked out the ignition, I have not seen one like this
Can anyone enlighten me?
Also removed the race alternator cover.
So I will need a starter gear assy & a rotor.
Are the rotors all the same on these ??
Anyone have one they want to part with?
Stu
Stu
Zed til Dead
Looks like GPZ1100 Unitrak to me if it's connected to the Igniter it is probably in a plastic case
Looks like a unitrac output shaft so may be a whole unitrac motor See what the engine number is.
Gus
Gus
"Set the GRINDER on it"
Julian_Boolean
Z1100R has a Unitrak engine, that ignition pickup is standard Unitrak, if you want to fit a Dyna ignition you'll need a J engine casing
- z1000puddin
Julian
By the time I finish this build, you are probably gonna be fed up of my questions
Thanks.
Stu
Thanks.
Stu
Zed til Dead
