Lawson Jigsaw Project
z1000puddin
#1 PostAuthor: z1000puddin » Sat Jul 08, 2017 6:14 pm
Well then.
So, I proceeded to empty all the boxes & try to get some sort of order, to see just exactly what I have here...
The plan is to dry build it, then strip & send the various parts to paint , powder & polish.
I got to this stage today ....
What I do need to start with is...
* Clock assembly with a key
*Nose fairing & screen
* Starter motor
* a side stand bracket
I'm slowly getting through all the boxes & should have all emptied & on the shelf by tomorrow.
There seems to be lots of GPZ parts.
Also multiple brake discs, mostly all very good.
Multiple Clutches, Dyna S ignition plates, a scruffy kerker
A scruffy Harris, A pretty good V&H.
Some members have asked about parts, I will get back you guys via PM
Zed til Dead
LeeJackson
Re: Lawson Jigsaw Project
#2 PostAuthor: LeeJackson » Sat Jul 08, 2017 8:03 pm
That's a good stash of parts you have there Stuart, will be a fun project!! Looking forward to seeing it develop!
z1000puddin
#3 PostAuthor: z1000puddin » Sat Jul 08, 2017 8:43 pm
Thanks Lee,
If you are needing any parts, give me a shout, I'm still going thru
All the boxes, but there seems to be a lot of GPZ & J parts
Stu
Zed til Dead
swampy
#4 PostAuthor: swampy » Sun Jul 09, 2017 9:08 am
looks like you've got quite an inventory of parts there.
swampy
#5 PostAuthor: swampy » Sun Jul 09, 2017 12:11 pm
im thinking of fitting a dyna2000 to mine. so if you have a j ignition case (the housing not the cover) i would be interested.
garyd
#6 PostAuthor: garyd » Sun Jul 09, 2017 2:19 pm
Your a Glutten for punishment...the garage looks as if I had never paid you a visit!!!
z1000puddin
#7 PostAuthor: z1000puddin » Sun Jul 09, 2017 6:08 pm
Gary
I know, I seem to have more parts now than I did before you cleaned me out. :D :roll:
How's my old zeds going ? Have ya got them MOTD yet ?
Zed til Dead
z1000puddin
#8 PostAuthor: z1000puddin » Sun Jul 09, 2017 6:17 pm
swampy wrote:im thinking of fitting a dyna2000 to mine. so if you have a j ignition case (the housing not the cover) i would be interested.
Swampy
There is a complete bottom end unitrack, but no ignition housing, sorry
Stu
Zed til Dead
swampy
#9 PostAuthor: swampy » Sun Jul 09, 2017 6:23 pm
ho hum
Julian_Boolean
#10 PostAuthor: Julian_Boolean » Sun Jul 09, 2017 8:11 pm
I got my casing off eBay for £15, you can still buy them new for about 10 times what I paid.
z1000puddin
#11 PostAuthor: z1000puddin » Mon Jul 10, 2017 2:07 pm
Doing a bit more today.
Checked out the ignition, I have not seen one like this
Can anyone enlighten me?
What type of ignition is this . ??
Also removed the race alternator cover.
So I will need a starter gear assy & a rotor.
Are the rotors all the same on these ??
Rotor & starter gear assy Required
Anyone have one they want to part with?
Stu
Zed til Dead
Gus
#12 PostAuthor: Gus » Mon Jul 10, 2017 2:10 pm
Looks like GPZ1100 Unitrak to me if it's connected to the Igniter it is probably in a plastic case
Looks like a unitrac output shaft so may be a whole unitrac motor See what the engine number is.
Gus
"Set the GRINDER on it"
Julian_Boolean
#13 PostAuthor: Julian_Boolean » Mon Jul 10, 2017 2:39 pm
Z1100R has a Unitrak engine, that ignition pickup is standard Unitrak, if you want to fit a Dyna ignition you'll need a J engine casing
Gus
#14 PostAuthor: Gus » Mon Jul 10, 2017 3:01 pm
Doh!
Course it does, brain fart
Gus
z1000puddin
#15 PostAuthor: z1000puddin » Mon Jul 10, 2017 4:12 pm
Julian
By the time I finish this build, you are probably gonna be fed up of my questions :D :D
Thanks.
Stu
Zed til Dead
Users browsing this forum: Google [Bot] and 53 guests
